New Demo Project - Slow Motion Art Display
A project log for SmartLED Shield for Teensy 4
Drive high density and low cost HUB75 RGB Matrix Panels with the Teensy 4. Best way to use panels with the powerful SmartMatrix Library.
louis-beaudoinLouis Beaudoin 09/14/2020 at 13:160 Comments
I created a LED Art project I've been wanting to do for a long time, but wasn't really possible before the SmartLED Shield for Teensy 4 - check out the video below.  This project involves the Teensy 4 playing back an animated GIF in slow motion, and interpolating between frames 240 times per second to really smooth out the slow motion effect.
Continuum is a light art display that is continuously in motion, with options to move quickly, slowly, or incredibly slow.  The RGB LEDs in the display are updated 240 times per second, with unique images calculated each update.  A slider on the side of the display controls if the LEDs play back the content - currently Animated GIFs - in normal 1x speed, 1000x slower than normal, or anywhere in-between.
The frame is powered by the Teensy 4.1, and the SmartMatrix Library, using the [SmartLED Shield for Teensy 4](https://www.crowdsupply.com/pixelmatix/smartled-shield-for-teensy-4).  The LED panels are 32x32 pixel P5 (5mm pitch) RGB HUB75 panels combined to make a 96x96 pixel 480mm (18.9") square display that fits into an Ikea Ribba shadowbox frame.
I posted more details here on Hackaday.io, and more details including instructions on how to build your own over on Instructables.
