o-ring sizes
A project log for SRAM hydraulic brake o-ring
Swap or replace o-rings
thomasThomas 09/17/2020 at 03:420 Comments
SRAM force 11sp brake caliper:
Brake lever:
Piston: 17.85mm (aka 18mm)
Piston seal sources:
Different size piston available here (26mm OD) labeled as PE: https://www.aliexpress.com/item/4000509364502.html
