OEM fluid test
A project log for SRAM hydraulic brake o-ring
Swap or replace o-rings
thomasThomas 09/20/2020 at 16:560 Comments
OEM european power steering fluid (15-851OEM)
Appearance: green colored light liquid
May be similar to CHF 11S. Reported here 11S should be compatible with HNBR/NBR:
https://forums.mercedesclub.org.uk/index.php?threads/abc-valve-block-rebuild-pics-is-this-right.138407/page-2
SRAM oring tested in fluid:
SRAM oring should be EPDM. So maybe 851OEM oil has very similar compatibility to standard mineral oil?
NBR oring:
VQM (silicone):
https://forums.mtbr.com/brake-time/o-ring-material-question-680609.html
