This next example shows a potential security risk in the form of leaking sensitive information. Like all these examples, the full code is on Github but also shown here.
#include <string.h>
#define BUFFER_LENGTH 16
void process_secret_data(void)
char buffer[64];
int ssn = 555555555; // Should NOT be leaked
snprintf(buffer, 64, "SSN: %i", ssn);
// Do something with SSN...
void do_something_else(void)
char buffer[64];
Serial.println("Enter your Name");
int start = millis();
int index = 0;
while((millis() - start) < 5000)
if(Serial.available())
buffer[index++] = Serial.read();
Serial.print("Your name: ");
Serial.println(buffer);
void setup() {
Serial.begin(115200);
delay(1000);
Serial.println("Booting...");
delay(100);
void loop() {
delay(5000);
Serial.println("Loop still running");
process_secret_data();
do_something_else();
Here, we have some function "process_secret_data" that does something with sensitive information. It takes some social security number and processes it. Then, we have some other function "do_something_else" that asks the user for their name. Perhaps this would be used for some sort of login.
The main issue here is that the buffer in "do_something_else" is not zeroed out, and the buffer in process_secret_data is not cleared out before that function exits. The hardware does not clear that data either, so the buffer is not cleared out. These local variable buffers are put into similar addresses, and we can therefore access old sensitive data from a separate function.
Without inputting anything, we get the following (on a Adafruit Feather M0). It is printing whatever is in the buffer, finds a string terminating 0, and stops.
If we provide a short "name," we can overwrite the string terminating zero and cause it to print out more than expected. Here I provided the name "hello."
This program now leaks the sensitive information from this other function. We really do not want this to happen. We want to compartmentalize the code so leaks like this do not occur.
