Built two more I2C-IO & Bootloader Instructions
A project log for I2C-IO
A simple I2C connected microcontroller for real-world interfacing, distributed computing and edge-style data processing
mdlougheedmdlougheed 11/08/2020 at 20:360 Comments
With the success of the first build, I finished stuffing and IR soldering two more I2C-IO.  After programming and verifying the setup for Arduino, I'll hand solder the MOLEX right angle connectors and the terminal block used as a the external ground connection.
Notes to self on future builds:
I used an Atmel JTAG ICE-3 to program the 328PB's with the Arduino bootloader using Atmel Studio 7.
That pretty well does it to program the board in Arduino.
