So this project is finished and works fine. But I recently found in my drawer those Kailh scissor switches that I ordered a year ago to test, and forgot about them. So why not test them by making another Atreus-like keyboard? This switch of course has different footprint again, and with a hole in the PCB too, so a new design for the PCB is called for. And since I don't like to do the same thing twice, I removed the column stagger this time, and only included two keys in the middle.
![](https://cdn.hackaday.io/images/8883901605828094532.png)
I will also need the special key caps for this. Kailh has some super-ugly ones, but that will do for now, I suppose. As usual, the PCB is ordered and should arrive within a week or two, then I can assemble it all and try it.
