New release 0.5
A project log for Serial Data Visualization
Small .net based software that allows simplest possible data visualization and logging from serial port
evgenyEvgeny 10/12/2020 at 16:530 Comments
Using the word 'release' for such a project is a bit overkill, but in the absence of a better term...
so, the performance of the chart object of .net is not really adapted for heavy applications, however, if one disables it (like no interaction with system whatsoever), the redraw capabilities jump up drastically.
in the version 0.5 I also added some basic variable names recognition.
