Instability Followup and Resolution
A project log for Raspberry Pi Ceph Cluster
A Raspberry Pi Ceph Cluster using 2TB USB drives.
robert-rouquetteRobert Rouquette 03/30/2022 at 15:360 Comments
The OSD instability I encountered after the kernel update persisted though with less frequency.  I've finally determined that cause is a confluence of small issues that amplify each other:
I've remediated the instability by underclocking the CPU.  Underclocking was insufficient on its own, so I've also applied slight overvoltage as well.  The OSD RPi's have been holding steady after applying both changes.
Here's the current state pf my usercfg.txt:
# Place "config.txt" changes (dtparam, dtoverlay, disable_overscan, etc.) in
# this file. Please refer to the README file for a description of the various
# configuration files on the boot partition.
max_usb_current=1
over_voltage=2
arm_freq=500
These changes have not appeared to impact my Ceph performance.
