Simple Python Interpreter and Plan
A project log for Kyazuken: a Java-like language
Java is great. Could I roll my own?
Dylan BrophyDylan Brophy 10/26/2020 at 00:330 Comments
The interpreter can run simple programs but is basically a limited C interpreter for now
void main(String[] args) {
	println("Hello World!");
	if (1 + 1 == 2) {
		println("1 + 1 = 2!");
	exit(0);
 This executes.  It's not super hard to get running because I had code from the last language I tried to make, written in Python 3 using rply.
I want a compiler that can compile itself.  So my plan:
  1. Write a basic compiler in Kyazuken
  2. Get the interpreter to interpret it
  3. Try to compile the compiler with itself in the interpreter
I want to output some intermediate language like RTL so I can generate machine code with GCC.  This way I could quickly generate compiled code for any processor.
