Nest Controller Assembly
A project log for Apartment HVAC IoT
Bringing analog hvac system into home automation.
pydrewPyDrew 03/16/2021 at 16:240 Comments
The circuitry and PCB to interface with the Nest Thermostat followed the same process as the HVAC Controller needing a second revision.
And final assembly:
