Simple Mixer
A project log for Very Simple Dual Active Mixer 3 x INPUT 1 x OUTPUT
Very Simple Dual 3xINPUT 1xOUTPUT for Eurorack/Kosmo Synthesizer System
neil-mundtNeil Mundt 02/06/2021 at 22:450 Comments
Half of the schematic for a Simple eurorack mixer. You can Use a TL074 or TL072. Depends on how many Op amps you decide for your mixer.
The First op amp(U1.1) Inverts and Amplifies the mixed voltages with a Gain of 1.
Then that is fed into the second op amp(U.1.2) Inverts and Amplifies the mixed signal phase back to the Original Phase with a Gain of +1.
You can add as many Inputs as you want. I am probably going to make 4xInput 2x Output Version for my Rack. You can never have too many mixers.
