Software support
A project log for Raspberry Pi AVR ISP hat
A small board to adapt the Pi SPI interface to AVR programming
nick-sayerNick Sayer 11/02/2020 at 18:170 Comments
avrdude 6.3 comes with a bit-banged GPIO driver that is suitable for use with this hat. All you need to do is add this to your avrdude.conf file:
programmer
    id = "pihat";
    desc = "Use the Linux sysfs interface to bitbang GPIO lines";
    type = "linuxgpio";
    reset = 25;
    miso = 9;
    mosi = 10;
    sck = 11;
This works, but there is a higher performance variant of this that actually uses the Pi SPI bus. To use it, you must first enable SPI in raspi-config. Once this is done, you'll see /dev/spi0.0 show up. Apply the patch (see below) to avrdude and then add this section to your avrdude.conf file:
programmer
  id = "pihat";
  desc = "Use Linux SPI device in /dev/spidev*";
  type = "linuxspi";
  reset = 25;
  baudrate=100000;
The patch to avrdude is here. This patch also adds support for using the TPI adapter for TPI programming.
