The kit includes a power supply module.
It is designed to be mounted on a full size breadcrumb and can output 2 voltage (one for each row).
Voltage can be selected by a jumper : 3.3 V or 5 V.
The switch next to the pin turns on or off the module.
I’ve used a 12 V HDD power adapter that fitted perfectly.
