LightBurn take 2^42
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 06/05/2022 at 21:370 Comments
So recently I got a paid commission.  A Facebook acquaintance of my wife's needed a quick bunch of balloons cut out of plywood for a party.  It was a rush job that I put together in one day, and I ended up putting a few hours on it as well as using a full sheet of wood so I charged $30.  If it was a repeat cut that I could take a few days on I would have charged $20.
Between that job and all my cardboard elephant cutouts I have been pushing the laser extra hard recently.  For starters it is 110 F in my garage, and that is making it difficult for the laser to stay cool.  I'm only running it at 80% power, but the housing is hot to the touch.  I can still hold my finger on it, but it is uncomfortable and probably too high if I want my diode to last a long time.
Another issue is my on going struggle to get Lightburn to work well with my grbl controller.  I can't tell you how frustrating this is. Every other sender is happy to work in a virtual coordinate mode as well as an absolute mode with a properly homed system.  Lightburn on the other hand is overly picky and that makes this a really frustrating experience.
The recommended solution is to home the machine and mess with the coordinate system to force it into a positive workspace.  Previously I had made a macro to do this, but it still trips you up if you forget to home the machine, or if the moon is in retrograde and so on.
This is my 3rd (5th?) attempt to fix this.  I reset all of Lightburn settings back to there defaults and made a new macro that not only resets the coordinates, but homes the machine and then moves the laser to 0,0 in preparation of the first cut.  Since I have my new laser bed with a fixed edge that is very reliable I can set this up with some precision.  I ended up switching the laser to absolute coordinates at the same time.  That makes 0,0 be the farthest lower left corner of the machine no matter where I place the part on the lightburn workspace. Hopefully that will reduce instances of the cut start point moving around at random on the machine.
$32=1 ; turn on laser mode
$10=0 ; set coordinates to work position mode (virtual coordinates)
$H ; Home the machine
G10 L2 P1 X-340 Y-433 ; set work offset to -340,-433 or lower left corner
G90 X0 Y0 ; fast move to 0,0 position
Above is my macro, with comments.  I'm not sure that lightburn can handle comments, you may need to strip those out if you use this. And be sure to home the machine using UGS and then jogging over to your lower left (safe) edge to get the -x,-y values, don't use mine or you will most likely crash.
This seems to be working ok, now that homing is built into the macro it is more difficult to mess things up.  However there are still issues, for example if I move a design off the lower left corner of the workspace even by a fraction of a mm then the whole object won't be cut.  Yet Lightburn won't prevent me from moving off the corner, or snap to the corner properly either, and I only get a hint about the problem when I go to engrave, rather than having the object blink or turn red.
Hopefully this helps in the long run, but I find it very frustrating that I have to keep messing with this and there are no aids to help get it going.  I don't see how most CNC users manage to get Lightburn to work safely out of the box.  Especially when tools like  UGS seem to get it right the first time straight out of the box.  There doing things in the name of safety, but I never have UGS shoot off in a random direction while Lightburn has crashed into the side of my machine several times for no apparent reason.
