UGS
A project log for MultiBot CNC v2
A low cost 3D printed CNC that can be built with minimal tools yet is capable of great things.
david-tuckerDavid Tucker 07/22/2022 at 04:410 Comments
I put in a bug log a while back reporting that UGS was improperly rendering rotary gcode.  Well they really came through and put in a fix a few weeks ago, and you can now download the fix from the nightly build.
Here it is rendering my bat project, you can see it is doing a lot better than previously.
It is much better, but it is still not perfect.  Here I'm trying to make a 80 degree spiral but instead the x and a axis are moving one after the other.
And here I have sub divided the spiral into smaller segments.  You can see the intended shape better, but it is still just stair stepping rather than spiraling.
You can download the above example code here.
