Init
A project log for SuperNight 2
2 Channel Wifi LED Dimmer
andyAndy 12/14/2020 at 17:540 Comments
I've been toiling on this for around two months now, and I just put in the PCB order and parts order today. Sometime early next week, Assembly and testing will begin.
The PCB features are as follows:
12V-24V Input voltage
8A per-channel (16A Max)
Programming / Debug header
i2c header for OLED display
Input Voltage monitoring
Mosfet temperature monitoring
The software stage will hang me up a little more. Between learning the ins and outs of the ESP-32 and designing a user interface, I expect that it will be a steep climb. Nonetheless, I hope to have some sketches soon of the flow of the menu system, and the case design as well.
