Implementing the SIMPL Machine.
A project log for SIMPL
Serial Interpreted Minimal Programming Language for exploring microcontrollers & new cpu architectures
monsonitemonsonite 01/14/2021 at 22:190 Comments
The previous log The SIMPL Machine, looked at how the J1 Forth CPU simulation could be used as the basis of a cpu targeted to execute the SIMPL language.
Here are some notes regarding the implementation on the Teensy 4.0
A switch-case structure will translate the SIMPL ascii character commands into 16-bit instructions to feed the J1 cpu simulated cpu.
I took the SIMPL text interpreter framework and mapped into it the J1 instructions, focusing initially on the stack, ALU and memory operations – listed below
SIMPL               Operation                J1 hex code
”                   DUP                      6081
‘                   DROP                     6183
$                   SWAP                     6180
%                   OVER                     6181
+                   ADD                      6203
&                   AND                      6303
|                   OR                       6403
^                   XOR                      6503
~                   INV                      6600
@                   FETCH                    6C00
!                   STORE                    6123
