Printing the base and tower
A project log for Animatronic LEGO Lunar Lander
Goal is to simulate a lunar landng and take off with the LEGO Lunar Lander
Mark HoweMark Howe 01/22/2021 at 19:210 Comments
After some thought, I've decided to print the base and tower. I figure I can always go back to the orginal plan of constructing it out of wood if it doesn't work out. It will just take some time. PLA with a fill density of 5% seems to be strong enough. With a little filler and sanding it should look good. Nothing is glued yet.
