here is how to measure voltage to vl53l0x chip. thru the SDA line
A project log for 10x improve VL53L0x. Volts, laserPOW analog mod
collecting data on distance variation, room temp, voltage on chip, and laser power, results: laser and voltage compensate improve accuracy!
jamesdanielvjamesdanielv 01/21/2021 at 02:460 Comments
the SDA line is pulled high with a 2k to 10k resistor normally. so when the i2c is idle, measuring the SDA line pin with a 100k resistor, and 100k to gnd will put the adc within a range to see up and down voltage changes. you can use gnd, or a output pin put to gnd, you will need to verify voltage with a volt meter across gnd of 100k resistor and adc pin to adjust gain to see what actual voltage is.
