[HEX]POD a11.3 updates!
Finally! after a long pause due to job things i am back at the [HEX]POD!
Biggest update is the temporary change to a reduced form factor, a MVP (minimum viable product).
I chopped off the lower 2/3rds and fit everything into the top portion of the earlier designs.
Other updates:
- new PCB#1 fully working (small bugs)
- first PCB#2 almost fully working
- core functions up and running
- Dev interface programmed
- Web interface programmed
I made some great progress which i will share over the next weeks.
Here is a sneak peek at whats coming:
more soon, thanks for reading!
Manu
