^6 Serial Checked With Raspberry Pi
A project log for RPUadpt - a shield for multidrop serial over CAT5
Serial mezzanine with management for host to one or many targets.
ronaldsutherlandronald.sutherland 07/18/2018 at 03:260 Comments
The Remote firmware has the Raspberry Pi locked out from using the serial connection, but with I2C1 it can be enabled. One of the status bits is for host lockout. I2C command 7 is used to set that status bit.
python3
import smbus
bus = smbus.SMBus(1)
#write_i2c_block_data(I2C_ADDR, I2C_COMMAND, DATA)
bus.write_i2c_block_data(42, 7, [0])
#read_i2c_block_data(I2C_ADDR, OFFSET, NUM_OF_BYTES)
#OFFSET is not implemented
print(bus.read_i2c_block_data(42,0, 2))
[7, 0]
exit()
picocom -b 38400 /dev/ttyAMA0
Terminal ready
/1/id?
# C-a, C-x.
Once the host lockout is clear the Raspberry Pi can bootload the address set with command 3 (see Remote). The Raspberry Pi will need to use its RTS handshack lines for avrdude to work.
^6 fwRemote_and_Rpi
