Fume extraction hose
A project log for 3D printable 125mm butterfly valve
A 3D printable servo controllable butterfly valve for my air filter system
fabianFabian 02/17/2021 at 19:400 Comments
I added a small guide to build a fitting solder fume extraction hose. Please see the attached pictures. You can find the build instructions incl. stl files and more pictures here: https://nerdiy.de/en/howto-3d-druck-loetrauch-absaugschlauch-inkl-trichter-selber-bauen/
