Minor differences between the DA and DB series recommended capacitors
A project log for AVRxDA28 Target
A Dev board for the new AVR DA series (and even DB series) microcontrollers
mcunerdmcu_nerd 10/24/2022 at 22:450 Comments
Looking at the datasheets for the AVR64DA28 and AVR64DB28 there are a few minorish differences for capacitors.
For the AVR64DA28 for the main VCC pin decoupling:
100 nF capacitor for the main decoupling
a 1-10 nF capacitor for decoupling at HF frequencies
a 1 uF capacitor listed as optional
For the reset pin:
100  nF capacitor
For the AVCC pin decoupling:
nothing listed
For the AVR64DB28 for the main VCC pin decoupling:
1 uf Capacitor for the main decoupling
10-100 nf Capacitor  for decoupling at HF frequencies
For the reset pin:
1 uF capacitor
For the VDDIO2 pin decoupling:
On my board pads labeled C1,C2 are connected to the main (digital)VCC pin.
C3 is connected to the AVCC pin.
C4 is connected to the reset pin.
I should perhaps in the future at least add a capacitor pad for VDDIO2 pin if using a DB variant.
