Power Management
A project log for BALT - Digital Barometric Altimeter
LCD Baro altimeter with climb, descent, vertical speed, & temperature.
brian-cornellBrian Cornell 02/05/2021 at 03:530 Comments
To maximize battery life the design uses the PIC's sleep and XLP (eXtreme Low Power) features:
In deep sleep the bias current is ~ 32uA which gives the unit a theoretical shelf life of about 260 days with a typical 200mAh battery. When on, but with no user navigation, it is ~ 910uA with sample peaks of 6mA for 10mS. Ignoring the peaks you'd get about 9 days of use with the off timer disabled. So, actual battery life depends heavily on the amount of use and timeout setting.
