Schematic diagram uploaded
A project log for 4017 Decade Logic Clock
A digital clock that displays the time using LED's numbered from zero to ten.
ian-dunnIan Dunn 02/20/2021 at 19:470 Comments
Based on your feedback, (thank you!) I've uploaded the schematic diagram of this clock. If you'd like to try building it on your breadboard, it should work. Thank you!
