Similar board, from Control Universal catalogue 1987
A project log for STEbus Advanced Colour Graphics
Based on the Hitachi HD63484 ACRTC
keithKeith 10/30/2021 at 13:180 Comments
Celeste/484 High Resolution Colour Graphics
Features:
Celeste/484 is the powerful graphics processor card of the Control Universal range of STE cards. The Hitachi 63484 controller has three processors, one to manage the screen display, the second to manage all CRT timing functions, and the third to perform all the drawing operations. Commands supported directly via simple parameters include circle, ellipse, polyline, arc, paint, etc. A choice of screen access modes allows either full resolution (by drawing only during flyback) or higher drawing speeds by interleaving screen display and drawing times. Up to 1600 pixels can be displayed horizontally with standard 15.75 kHz line rate monitors. Other resolutions are obtainable under software control or by changing the pixel clock frequency.
Version A has the INMOS colour palette allowing a choice of 256 colours from 262,144. Selected colours may be flashed at variable rates. Different palettes may be loaded from the host CPU. Output drives analogue or TTL monitors.
Version B has no colour palette and drives TTL monitors only.
External Connectors:
Version A: 5 SMB 'subclic' coaxial connectors for analogue monitors.
Version B: 9-way standard mini "D" type connector
           providing RGBI and Sync for TTL monitors.
Board Dimensions: 100 × 160mm to STE IEEE P1000 specification.
Board Power Consumption: +5V, typically < 1000mA
Celeste/484A - With INMOS colour palette	SE485AA		£765
Celeste/484B - No INMOS colour palette		SE484AA		£595
