Replacement Parts
A project log for Tyco Trucking US-1 Resurrection
This is documenting my journey getting a getting and old Tyco Trucking Set up and running with my kids.
mike-turveyMike Turvey 02/18/2021 at 05:450 Comments
When looking at e-bay for Tyco US-1 parts, it's quickly apparent that there are a number of plastic parts that commonly break over time.  One of the first I ran into was for the box unloader.  You can find the main track piece for this very frequently, but there's a special sign that only swings one way that is almost always broken or missing.
One of my big hobbies is 3D printing (and designing 3D parts).  As for Tyco US-1, my interest is less in having everything be perfect & stock, and instead in having something that I can feel comfortable having my kids pull out and play with.  I expect that some things will get broken, and that needs to be okay.  I also love that, with 3D design, I can design something once, and then not only can I re-print it as many times as I want, but others can as well.  All it takes is one person to design a bunch of simple replacement parts, and then all of these broken, unusable parts are suddenly more valuable and easily restored.
So yeah, you probably guessed that I designed a replacement sign & sign post:
Functionally, it works great.  And while the picture gives you a close-up view where you can see all of the printing imperfections, in practice, they're not so visible, and it works great.
https://www.prusaprinters.org/prints/55299
From this point, I've jumped off and started designing a number of other parts that seem to break often:
The dump yards are super common, but the original walls are frequently warped, have their pegs broken off, or are just flat missing.
https://www.prusaprinters.org/prints/55300
I picked up a "Motor City Trucking" car carrier loader (I never had one of these as a kid, but it looks cool!) The "backstop bracket" was broken, but easily replaced with a 3D printed part (grey bracket in the middle).
https://www.prusaprinters.org/prints/57106
The shed was missing on this Freight Terminal.  This was kind of a fun build, as I designed the building to be printed flat, and folded, just like the original building was assembled.  It's a surprisingly simple design that allows all of the walls to be printed as a top surface of the 3D print (so they look nice), without the need for gluing anything together.  It's interesting how using a similar design that worked so simply with injection molding applies so well to 3D printing.
https://www.prusaprinters.org/prints/55307
