Sparkfun's MicroOLED library ported to 2 platforms
x-bzip - 17.06 kB - 02/21/2021 at 18:17
x-bzip - 405.47 kB - 02/21/2021 at 02:57
Got the STM32F407ZGT6 running on Arduino. All I did is select the correct board and pins. See below:
/* * Board: Generic STM32F4 series * Board part number: VCCGND F407ZGT6 Mini * * OLED - STM32F4 connexions * STM OLED 0.66" Sparkfun 64x48 pixels #LCD-13003 * GND 1 GND * 3.3V 2 VDD * PA7 3 D1/MOSI * PA5 4 D0/SCK * -- 5 D2 * PB0 6 D/C * PB1 7 nRESET * PA4 8 nCS */ ////////////////////////// // MicroOLED Definition // ////////////////////////// #define PIN_RESET PB1 #define PIN_DC PB0 #define PIN_CS PA4 #define DC_JUMPER 0 // Set to either 0 (default) or 1 based on jumper, matching the value of the DC Jumper // Also connect pin PA5 to SCK and pin PA7 to MOSI
The rest of the code is the same as the Micro OLED example.
View project log
hIOTron
adamc
Mike Szczys
Sergio Ghirardelli
Yes, delete it Cancel
You are about to report the project "MicroOLED library ports", please tell us the reason.
