Easy Raspberry PI Cluster Setup with Cloudmesh from MacOS
Set up many SD Cards directly from MacS that are preconfigured to create PI clusters.
By Gregor von Laszewski (laszewski@gmail.comlaszewski.github.io), Richard Otten, Anthony Orlowski Adam … | 2021.02.23
In this tutorial, we explain how to easily set up a cluster of Pis on a Mac while burning preconfigured SD Cards. We assume you use an SD Card reader/writer that is plugged into your manager PI that we configure initially with Pi Imager.
Learning Objectives
Topics covered
1. Introduction
Over time we have seen many efforts to create Clusters using Pi’s as a platform. There are many reasons for this. You have full control over the PIs, you use an inexpensive platform, and you use a highly usable platform and provides an enormous benefit to get educated about cluster computing in general.
There are different methods of how to set up a cluster. This includes setups that are known under the terms headlessnetwork booting, and booting from SD Cards. Each of the methods has its advantages and disadvantages. However, the last method is most familiar to the users in the Pi community that come from single Pis. While reviewing the many efforts that describe a cluster set up most of them contain many complex steps that require a significant amount of time as they are executed individually on these Pis. Even starting is non-trivial as a network needs to be set up to access them.
Despite the much improved Pi imager and the availability of Pi bakery, the process is still involved. So we started asking:
Is it possible to develop a tool that is specifically targeted to burn SDCards for the PIs in a cluster one at a time, so we can just plug the cards in, and with minimal effort start the cluster that simply works?
You are in luck, we have spent some time to develop such a tool and present it at as part of PiPlanet1 . No more spending hours upon hours to replicate the steps, learn complex DevOps tutorials, but instead get a cluster set up easily with just a few commands.
For this, we developed cms burn which is a program that you can execute either on a “manager” Pi (or in a Linux or macOS computers) to burn cards for your cluster.
We have set up on GitHub a comprehensive package that can be installed easily we hope that it is useful to you. All of this is discussed in detail at the cloudmesh-pi-burn README2. There you can also find detailed instructions on how to use a Mac or Linux computer to burn directly from them. To showcase to you how easy it is to use we demonstrate here the setup of a cluster with five nodes.
2. Requirements
For a list of possible part choices, please see:
3. The Goal
We will be creating the following setup using 5 Raspberry Pis (you need a minimum of 2, but our method works also for larger numbers of PIs). Consequentially, you will also need 5 SD cards for each of the 5 Pis. You will also want a network switch (managed or unmanaged) with 5 ethernet cables (one for each Pi).
Figure 1 shows our network configuration. From the five Raspberry Pis, one is dedicated as a manager and four as workers. We use WiFi between the manager PI to allow for you to set it up anywhere in your house or dorm (other configurations are discussed in the README).
We use an unmanaged network switch, where the manager and workers can communicate locally with each other, and the manager provides internet access to the workers via a bridge that we configure for you.
Figure 1: Pi Cluster setup with bridge network
4. Set up the Cloudmesh burn program on your Mac
On your Mac do the following. First set up a Python venv:
user@mac $ python3 -m venv ~/ENV3
user@mac $ source ~/ENV3/bin/activate
Next, install the cloudmesh cluster generation tools and start the burn process
(ENV3) user@mac $ pip install cloudmesh-pi-cluster
(ENV3) user@mac $ cms help
(ENV3) user@mac $ cms burn info
(ENV3) user@mac $ cms burn cluster --device=/dev/disk2 --hostname=red,red01,red02 --ssid=myssid -y -g
Fill out the passwords and plug in the cards as requested.
5. Start your Cluster and Configure it
After the burn is completed, plug them in your PIs and switch them on. On you Mac execute the ssh command to log into your manager we called red. Worker nodes have a number in them.
(ENV3) user@mac $ ssh pi@red.local
This will take a while as the file system on the SD Cards need to be installed and configurations such as country, ssh, and wifi need to be activated.
Once you are in the manager install cloudmesh cluster software also in it (we could have done this automatically, but decided to leave that part of the process up to you in case you to give you maximum flexibility).
pi@red:~ $ curl -Ls http://cloudmesh.github.io/get/pi | sh -
.. after lots of log messages, you will see …
# Install Completed                             #
Time to update and upgarde: 339 s
Time to install the venv:   22 s
Time to install cloudmesh:  185 s
Time for total install:     546 s
Time to install: 546 s
Please activate with    source ~/ENV3/bin/activate
Now just reboot with
pi@red:~ $ sudo reboot
6. Use your Cluster
On your Mac say again
Once you are logged in in your manager named red.local on the network execute a command to see if things work. Use our temperature monitor to get the temperature from all PIs. This will allow you to see if they are all working.
(ENV3) pi@red:~ $ cms pi temp red01,red02
pi temp red01,red02
| host   |    cpu |   gpu | date                       |
| red01  | 45.277 |  45.2 | 2021-02-23 22:13:11.788430 |
| red02  | 42.842 |  42.8 | 2021-02-23 22:13:11.941566 |
8. Accessing the workers from the Mac
To makes it even more convenient, we want to access the workers directly from the Mac. For this reason, we have designed a tunnel command that makes the setup real easy. You call it on the manager node as follows
(ENV3) pi@red:~ $ cms host setup red00[1-2] user@mac.local
This will print out a file that you need to copy it into to your ~/.ssh/config file on your Mac. We will soon have a command that will add them for you without using an editor.
# copy to ~/.ssh/config on remote host (i.e laptop)
ost red
     HostName red.local
     User pi
Host red001
     HostName red.local
     User pi
     Port 8001
Host red002
     HostName red.local
     User pi
     Port 8002
Now you are all set to access the workers on your Mac. Try it out with the temperature program
(ENV3) user@mac:~ $ cms pi temp red,red00[1-2]
| red    | 50.147 |  50.1 | 2021-02-18 21:10:05.942494 |
| red001 | 51.608 |  51.6 | 2021-02-18 21:10:06.153189 |
| red002 | 45.764 |  45.7 | 2021-02-18 21:10:06.163067 |
7. More Information
As we use ssh keys to authenticate between manager and workers, you can directly log into the workers from the manager.
More details are provided on our web pages at
Other cloudmesh components are discussed in the cloudmesh manual4.
Acknowledgement
We would like to thank the following community members for testing the recent versions: Venkata Sai Dhakshesh Kolli, Rama Asuri, Adam Ratzman. Previous versions of the software obtained code contributions from Sub Raizada, Jonathan Branam, Fugang Wnag, Anand Sriramulu, Akshay Kowshik.
References
  1. PiPlanet Web Site, https://piplanet.org ↩︎
  2. Cloudmesh pi burn README, https://github.com/cloudmesh/cloudmesh-pi-burn/blob/main/README.md ↩︎
  3. Parts for building clusters, https://cloudmesh.github.io/pi/docs/hardware/parts/ ↩︎
  4. Cloudmesh Manual, https://cloudmesh.github.io/cloudmesh-manual/ ↩︎
