Before starting to design, I had made a project with multiple modules to verify. The modules I prepared:
- Maduino A9G module
- An anemometer
- DHT11 module
- Buzzer
I use the A9G module to report the data with MQTT, and use the ESP32 module with a display to subscribe to the data from the MQTT broker.
You can click here to view the detail of the test if interested.
Makerfabs
