Verify
A project log for wind weather station
This is a product match the anemometer to measure the wind speed, also provide other interfaces and sensor to measure tem, hum, and so on.
makerfabsMakerfabs 03/01/2021 at 10:040 Comments
Before starting to design, I had made a project with multiple modules to verify. The modules I prepared:
I use the A9G module to report the data with MQTT, and use the ESP32 module with a display to subscribe to the data from the MQTT broker.
You can click here to view the detail of the test if interested.
