Air inlet/outlet valve concept (VOTE)
A project log for Plant pod
Modular plant grow module
Nikola SecerovskiNikola Secerovski 03/20/2021 at 14:132 Comments
Here are some of the air inlet/outlet design concepts, help us to choose wisely...
1. Vader
2. Eve
3. Bee hive
---------- more ----------
More images and details
This is a cross section of the modular air IO valve, with 30x10 mm PWM fan (Not shown in the rendering).
The idea is that these air IO valves can be added, removed or combined in any desired way depending on the plant itself.  By utilizing this kind of design, we open more possibilities for further development of the Plant pod device, like external air supply, etc. Air IOs are connected to the top of the device using pogo pins, like this:
Vote for the design You like the most, and help us decide ;)
Mihailo Stefanovic wrote 03/20/2021 at 18:37 point
3. Bee hive :)
Nikola Secerovski wrote 03/20/2021 at 18:20 point
1. Vader
