Along with information about parts used for the assembly of the COMIX-35, I'll add in some recommendations for tools and other secondary items that will help your assembly process. The first one I want to recommend is that you have a really good set of wire cutters. Most of the components will come with long wire leads that will need to be trimmed after soldering them in place. These Plato wire cutters are super sharp and make quick clean work of trimming the leads. They are available on Amazon with prime shipping of a two pack for $11USD.
