The USB port is connected on PB15 and PB14 (OTG HS).
To enable the Serial on this port, you have to configure the compiler options in the Arduino IDE :
In "Tools" choose :
- U(S)ART support : Disabled
- USB support : CDC generic serial
- USB speed : High speed in full speed mode
Now the board should be reconized as an USB device
