When modelling hardware you run into the subject of multi-value logic. Inevitably, because digital logic is more than just ones and zeroes: there's also high impedance signals and their interactions with other signals to model.
Thus I had to settle upon a multi-value logic system for hdlpy.
VHDL
I'm most familiar with VHDL and its 9-valued logic system from IEEE 1164:
U | Uninitialised |
X | Strong unknown |
0 | Strong logical zero |
1 | Strong logical one |
Z | High impedance |
W | Weak unknown |
L | Weak logical zero |
H | Weak logical one |
- | Don't care |
The main advantage of VHDL's system being that it allows you to model wired logic by using weak signals (W
, L
and H
). However, hdlpy is intended for FPGA's, which typically don't do any wired logic (even high impedance signals are rare, only appearing on external pins).
Verilog
Verilog sticks to the much simpler 4-value logic system as defined in IEEE 1364:
0 | Logical zero |
1 | Logical one |
X | Unknown |
Though missing weak signals, it does include high impedance signals which may appear on external FPGA pins.
hdlpy
Thus for hdlpy I settled on the Verilog system of 4-valued logic (0
, 1
, Z
and X
Which then led to the challenge of deriving logical operations on these values. Of course, 0
and 1
are easy:
>>> from hdlpy import logic
>>> logic(1) & logic(0)
<logic.zero: '0'>
>>> logic(1) & logic(1)
<logic.one: '1'>
>>> logic(1) | logic(0)
<logic.one: '1'>
But what if one of the operands is Z
or X
I realised that a logical AND where one of the operands is 0
can only ever result in 0
, irregardless of the second operand. The same goes for OR where one of the operands is 1
>>> logic(0) & logic('Z')
<logic.zero: '0'>
>>> logic(1) & logic('X')
<logic.unknown: 'X'>
>>> logic(0) | logic('Z')
>>> logic(1) | logic('X')
<logic.one: '1'>
Indeed, VHDL and Verilog both define similar truth tables.
Use the source!
Source code for hdlpy, together with a test suite, is available on GitHub.
