A stand
A project log for Ribbon Speaker
Based on JGJMatt's Instructable.
jeremy-gJeremy g. 03/30/2021 at 13:100 Comments
I'm trying to figure out how best to present the speaker next to its amp. Since I went with copper for the guards on the face I kind of want to incorporate that with the stand as well but not quite sure how I'm going to execute it yet.
I came up with an idea for a quick stand, then quickly realized it would not work the way I intended, the idea was to have the two clasps of the stand connect to the speaker horn, however I forgot to take into consideration that the speaker would just slide down as the clasps are holding the speaker by the horns slots... fixed that with a small support under the speaker, so no positional adjustments.
I'm not married to the design, I thought I would post it anyway and see if anyone had any suggestions.  Mind you this speaker is intended to be 3d printed and wont be as shiny as the render -_-. But we can see what we can do to spruce it up a bit.
