The variable
A project log for Pisano-carry Checksum algorithm
Add X to Y and Y to X, says the song. And carry on.
Yann Guidon / YGDESYann Guidon / YGDES 04/11/2021 at 23:353 Comments
Adding bytes together modulo 256 (for example) is not enough. The problem is the MSB : carries from lower bits or more MSB from other data items will overwrite the data, and/or "carry out/away" the datum. This is a well-known problem that Adler solves with a modulo-prime accumulator, so the MSB is fed back to the LSB "in a certain way". But this does not come for free.
So let's see what comes for free : use the widest possible registers and keep some headroom to store the entropy that would be "carried out" at the MSB. Ideally we use a 64-bit number where the checksummed data is accumulated at the lower half (32 bits at a time, screw endianness !) and the remaining high 32 bits work as an entropy buffer. At the end of the checksum loop, the two halves can be combined with a simple XOR if fewer than 64 bits are required.
uint64_t X, Y;
uint32_t *buff;
// init:
X = 1;
Y = 42;
// loop body:
Y += (X + buff[i  ]);
X += (Y + buff[i+1]);
i+=2;
// finish : Z is the LAST destination register.
Result = (uint32_t) (Z ^ (Z>>32));
Experience says that the tricky part is the cast from a smaller data size but RISC processors should handle this well:
For x86, it's not exactly easy but the 32-bits version is trivial thanks to the "ADDC" opcode, so it's safe to assume the trick creates no architectural bottleneck, for superscalar or OOO cores.
Some approximate calculations show that it takes about 44 iterations (or 22 X & Y passes) to fill 32 bits starting a value 1. http://oeis.org/A000045/list lists only until the 40th value (which is about 100 millions). But this is not really a problem because lower bits of the enormous number will still linger inside these 32 bits, as deformed echoes from the value.
Thomas wrote 04/20/2021 at 05:22 point
I'm not sure I'm getting the bit about the Carry and the Z right:
1. is the Carry flowing from the Y to the X operation?
2, is Z the combined X,Y register?
If any of that is wrong and the explanation is in some other log entry in the project, please let me know it. Otherwise, please explain :-)
Yann Guidon / YGDES wrote 04/20/2021 at 16:27 point
I understand your confusion.
The algo has evolved since this log. The version of this log is untested, speculative and incomplete because the carry is not properly handled.
By "Z" I meant either X or Y, whichever was last computed.
I have updated the project description with the tested algorithm:
t = X + Y + C; Y = X ^ data;
C = t >> 16; X = t & 0xFFFF;
I hoep this helps :-)
Thomas wrote 04/20/2021 at 18:25 point
Thanks, that looks neat :-)
Q1: do you have a sequence of data for testing?
Q2: would it be OK to use the algorithm in e.g. MIT licensed code?
