So I added an accumulation option to the dump7ck.tgz program. It took one second to get all these results:
opened log.02.p7k Sum = 9 opened log.03.p7k Sum = 35 opened log.04.p7k Sum = 135 opened log.05.p7k Sum = 525 != 527 opened log.06.p7k Sum = 2079 == 2079 ??? opened log.07.p7k Sum = 8157 != 8255 opened log.08.p7k Sum = 19205 != 32895 opened log.09.p7k Sum = 130660 -> bad != 131327 opened log.10.p7k Sum = 524799 opened log.11.p7k Sum = 2095074 -> bad != 2098175 opened log.12.p7k Sum = 8390626 -> bad != 8390655 opened log.13.p7k Sum = 33558525 != 33558527 opened log.14.p7k Sum = 134225869 != 134225919 opened log.15.p7k Sum = 536775078 -> bad != 536887295 opened log.16.p7k Sum = 2147516415 opened log.17.p7k Sum = 8589998505 != 8590000127 opened log.18.p7k Sum = 34359868345 != 34359869439 opened log.19.p7k Sum = 137419532490 -> bad != 137439215615 opened log.20.p7k Sum = 549742859919 != 549756338175 opened log.21.p7k Sum = 2199023259575 != 2199024304127 opened log.22.p7k Sum = 8796095119345 != 8796095119359 opened log.23.p7k Sum = 35184376226591 != 35184376283135 opened log.24.p7k Sum = 140737496743935 == 140737496743935 ??? opened log.25.p7k Sum = 562949764361284 -> bad != 562949970198527
We can already spot "obviously bad widths" by looking at the parity of the sum: the formula for the length of a maximal orbit is 2^(2w-1) + 2^(w-1) - 1 so the orbit length must be odd (for w>2). I have marked the even sums which clearly indicate that some orbits do not cross the Y=0 line. About one third of the sums are discarded this way.
For the real lengths, let's compute them:
$ for i in $(seq 1 26); do echo $i $(( ( (1 + 2**i)* 2**(i-1) ) -1 )) ; done
1 2
2 9
3 35
4 135
5 527
6 2079
7 8255
8 32895
9 131327
10 524799
11 2098175
12 8390655
13 33558527
14 134225919
15 536887295
16 2147516415
17 8590000127
18 34359869439
19 137439215615
20 549756338175
21 2199024304127
22 8796095119359
23 35184376283135
24 140737496743935
25 562949970198527
26 2251799847239679
(note: here I have used the "real" sum formula, while I often use another that does not count the transition x=0 to x=1 in many programs. But since this special case is now handled in the scanner, the true formula is back)
I have copied these values in the first dump. Only two known bad widths are remaining, w6 and w24.
w6 is quite interesting because it contains 6 orbits of equal lengths, now I wonder how many orbits w24 has and if their lengths are equal.
Overall, we see that the sum method is great at sieving non-maximal widths. It's also a good sanity check and it spots non-maximal widths, which may still be decent candidates.
Now it's time to program that fusion...
