OK I thought that the amount of data in the future would be too large and I decided to do the sieving in C.
Using the available scanning data, I could only go up to 2161 : n1=46 and n2=2114.
The first hicup comes at 1511 so there is no point in dealing with primes up to 1 million so far. I need way more scanning data.
So far the currently known sieve is:
11 3 7 19 4 14 29 5 23 31 12 18 41 6 34 59 25 33 61 17 43 71 8 62 79 29 49 89 9 79 101 22 78 109 10 98 131 11 119 139 63 75 149 40 108 151 27 123 179 74 104 181 13 167 191 88 102 199 61 137 211 32 178 229 81 147 239 15 223 241 51 189 251 117 133 269 71 197 271 16 254 281 37 243 311 58 252 331 116 214 349 143 205 359 105 253 379 19 359 389 151 237 401 111 289 409 129 279 419 20 398 421 110 310 431 90 340 439 69 369 449 165 283 461 21 439 479 228 250 491 73 417 499 224 274 509 121 387 521 99 421 541 172 368 569 232 336 571 273 297 599 24 574 601 136 464 619 242 376 631 109 521 641 278 362 659 200 458 661 57 603 691 221 469 701 26 674 709 170 538 719 329 389 739 118 620 751 210 540 761 91 669 769 338 430 809 342 466 811 28 782 821 212 608 829 95 733 839 341 497 859 276 582 881 326 554 911 67 843 919 316 602 929 30 898 941 227 713 971 173 797 991 31 959 1009 382 626 1019 493 525 1021 457 563 1031 106 924 1039 286 752 1049 325 723 1051 72 978 1061 459 601 1069 275 793 1091 211 879 1109 406 702 1129 327 801 1151 558 592 1171 113 1057 1181 533 647 1201 77 1123 1229 484 744 1231 269 961 1249 404 844 1259 35 1223 1279 599 679 1289 156 1132 1291 627 663 1301 267 1033 1319 399 919 1321 452 868 1361 82 1278 1381 609 771 1399 239 1159 1409 124 1284 1429 546 882 1439 700 738 1451 282 1168 1459 166 1292 1471 477 993 1481 38 1442 1489 680 808 1499 208 1290 1531 87 1443 1549 529 1019 1559 39 1519 1571 567 1003 1579 682 896 1601 605 995 1609 635 973 1619 764 854 1621 175 1445 1669 135 1533 1699 229 1469 1709 600 1108 1721 41 1679 1759 858 900 1801 426 1374 1811 185 1625 1889 823 1065 1901 97 1803 1951 146 1804 1979 44 1934 1999 949 1049 2011 735 1275 2069 45 2023 2089 611 1477 2099 665 1433 2129 792 1336 2161 46 2114
Of course, moduli 4 and 5 are treated separately. With now 143 known results, this program has decupled the size of the available sieve so it's now easier to finely check candidate moduli.
And as usual the source code is there : create_sieve.tgz.
