EQUATIONS Compile issues solved
A project log for Galaga meets IoT
ESP8266 captures high scores as they occur on a Galaga PCB from the Golden Age of Arcade
justinrichardsjustin.richards 11/07/2016 at 01:500 Comments
Solved the previous compile i8ssue with
Z := /Z
which toggles Z on every rising pulse on the Clock (Pin 1)
Z output is then used to differentiate between subsequent hi score digit writes.
This now fixes the issue where a high score with repeat digits such as 30556 would be interpreted as 3056.
Need to tidy the ESP8266 code and think about a final PCB board layout.
