Update and Warning:
It has come to my attention that various batteries do not all come with the positive and negative on the same side of the plug please ensure that the positive and negative on your battery pack is correct for the project. The positive red wire should pass through to the red wire on the harness linked to the switch. Note also that the 1200mah battery has been replaced with a 2000mah High Discharge rated unit.
This is the Digital Bird WIFI remote split away from the slider because it may also be used for other parts of the Digital Bird Camera motion control system independently and I decided it warranted its own project heading.
Component Kits : https://digital-bird-motion-control.myshopify.com
See it in action : https://youtu.be/0aQ5hq3H00k
Camera Slider : https://www.thingiverse.com/thing:4689312
Pan Tilt Head: https://www.thingiverse.com/thing:4842363
Software : https://github.com/digitalbird01/DigitalBird-Camera-Slider
