Cutworks where surprisingly fast (compared to the estimated delivery date in their mail (10. oct)). Everything turned out very nicely. The hood (sorry for bad quality, phone had problems with focus):
The the platters:
As you can see either two or four blades per platter and variable diameter are possible. Mowing some grass:
The new platters reduced the noise a lot, but there's still some vibration due to worn out bearings (previous designs rather unbalanced) and inaccurately modified motor shafts (previous designs needed a flattened shaft).
Best regards, Stefan
Schöne Grüße an euch beide :)
BTW: Drawings are here https://github.com/schuhumi/autocut/tree/master/Mechanics/Mowing%20deck
(can be opened with QCad for example)
Cutworks have a marvelous webinterface, you can just upload your .dxf drawings,
choose material/thickness and that's it. It was 65€ including shipping, which is
ok for individual parts produced in Germany I think.
Viele Grüße zurück :D
The Webshop thing is really awesome :)
To sad they only lasercut metals :(
Would also love to see engravings and Materials like wood and acrylics :-/
