The board will run the monitor software and boot the OS. I still have a problem with the CompactFlash card, but everything else seems to be working. I'm so happy, especially after making a mistake and using the wrong footprint for the two 16SSOP logic chips. I had to bend the pins under the package and try to solder them upside down, without hot air, just a fine tipped soldering iron.
