6# External Electronics Enclosure design
A project log for Dynamic 6-Axis Robot from scratch
I developed a 6 axis robot with half a meter reach and 3kg payload. It is servo driven and features absolut encoders on all axis.
adrian-prinzAdrian Prinz 08/15/2023 at 13:350 Comments
For housing all the electronics I designed a external electronics enclosure. This includes:
- Safety electronics
- 24V and 5V power supplies
- Motor drivers
- power distribution PCB
- main IO and sensor PCB
The roboter is connected to the enclosure via a single connector. Peripherals can be connected via a secondary connector.
The electronics enclosure:
Front side with E-stop, on of switch, Led indicators and HMI connector
Backside with the described connectors for the robot and peripherals:
