Wireing Diagram for CRYPTOiNK
A project log for CRYPTOiNK
Uses an E-ink Display to Realtime Update Select Crypto Currencys
John LoeflerJohn Loefler 06/04/2021 at 21:120 Comments
CRYPTOiNK uses a TP4056 Charger to charge a 6000mAh Lipo Battery.   Built into the Charger is a Low Voltage, Over Voltage, and Over Current Protection Circuit.
Because the Ilpo battery does not provide a constant voltage and ranges from 3.4 -  4.2V, a MT3608 DC/DC Boost Module to provide a consistent Voltage for the Waveshare Driver board to regulate down to a 3.3V that is used by the ESP8266 and Eink Display.
