HydraFW v0.2 Beta work in progress
A project log for HydraBus v1 Rev1.5
HydraBus v1 is an open source evolutive multi-tool which help you to Analyze/Debug/Hack/PenTest all types of electronic bus/chipset
benjamin-vernouxBenjamin Vernoux 10/16/2014 at 18:080 Comments
HydraFW v0.2 Beta is coming including template draft of mode plugin with same syntax as "buspirate" commands: see https://github.com/bvernoux/hydrafw/tree/master/hydrabus files xxx_mode_xxx.c/.h
This version add new sd commands and a microSD benchmark command (sd_rperfo) which run at up to 20MBytes/s
VT100 terminal is also now fully working thanks to Bert Vermeulen (biot) for the fixes in microrl and contributions for hydrafw code.
See https://github.com/bvernoux/hydrafw
See also Wiki: https://github.com/bvernoux/hydrafw/wiki
PS: Any contribution is welcome !! see https://github.com/bvernoux/hydrafw/wiki/Task-List
