Install and configure the pxlBlck plugin
A project log for pxlBlck - An unobtrusive home information display
A multifunctional home display and optical notification system for everyone
fabianFabian 05/31/2021 at 14:180 Comments
In addition to a few other articles, I have published an article to explain the installation and configuration of the pxlBlck plugin.
A small feature that I'm a little proud of (not because it's special, but because I've worked on it for a long time) is the color picker with which you can set the different colors of the screensaver or clock faces. The color can be set directly in the web menu of the ESPEasy plug-in and you don't have to enter RGB values manually (which is still possible). :)
The full article is available here: https://nerdiy.de/en/howto-pxlblck-das-pxlblck-plugin-installieren-und-konfigurieren/
