The Projector Part
A project log for Holographic Home Assistant Display
A cool add-on for Alexa, Google Home and Co.
alain-mauerAlain Mauer 06/08/2021 at 07:550 Comments
First I develop the lighting for the LCD display. The display is an ST7735 chipset with a resolution of 128*160 pixels.
I use a 3W led as the light source. It should be bright enough for my project and will not generate too much heat during continuous operation.
I also need to make a pre-lens out of resin to focus the light onto the display.
Here is the first test setup.
