Non-volatile configuration parameters
A project log for n00n - Real Time Music Sensor Streaming Protocol
MIDI is so outdated, welcome to the 20s and the 16-bit world !
yann-guidon-ygdesYann Guidon / YGDES 06/25/2023 at 00:140 Comments
Each device (in particular the sensors such as keyboards, pedals...) need to store parameters in either battery-backed up SRAM or EEPROM (for example). All active devices (those that do not affect the stream) should be able to answer the -3 Label and -4 Serial messages with the proper UTF-8 payload.
(note : the Serial string can be used as a seed to generate the candidate 16-bit IDs)
