Main plate design
A project log for Stock Ticker Machine
An old style stock ticker machine for the modern world
secretbatcavesecretbatcave 06/13/2021 at 17:310 Comments
Its not overly obvious in the hand drawn design, but the main point of the main plate is as follows:
Because aluminium is expensive, I started prototyping in plywood, to make sure my assumptions were correct, and that it all fitted inside the jar
Even though I had the mechanical drawings of the motors, I hadn't allowed enough space to fit all the paper handling bits in.
The other mistake I had made was not accounting for the width of the metal plate that holds the solenoids. Having learnt from my mistakes, and making some tweaks, I finally milled the aluminium plate
You can see some scratches in the black gloss, note to self, always finish your aluminium properly.
Its starting to look really nice now.
